 6pm
			6pm
			09-06-2005 09:55 AM
 biker2000
			biker2000
			09-06-2005 09:59 AM
09-06-2005 10:05 AM
Yes... thank's for your help. This is all of the nicanerr.txt that this forum can explain:
Service_Pack=Service Pack 4 (Build 2195)
[DRIVER_VERSION_SECTION]
NICAN.DLL_VERSION=2.2.0.300f
NICANFRM.DLL_VERSION=2.2.0.3040
DRIVERS\NICANPK.DLL_VERSION=2.2.0.3045
NICANPU.DLL_VERSION=2.2.0.300a
NICANTSK.DLL_VERSION=2.2.0.3021
NICANCFQ.DLL_VERSION=2.2.0.3000
NCVI.DLL_VERSION=2.2.0.300e
NICAN_S1.NFW_VERSION=20200000
NICAN_S2.NFW_VERSION=20200000
[CURRENT_SECTION]
Section_Index=0
[INDEX_9]
Local_Time= 09/05/2005 13:37:14.078
Err_Status= Status:0xb0910002-Location:0x30000000-Internal:0x00910000
Function= ncReadMult-CAN0::STD0X381
[INDEX_10]
Function= ncReadMult-CAN0::STD0X402
[INDEX_11]
[INDEX_12]
Local_Time= 09/05/2005 13:37:14.093
[INDEX_13]
[INDEX_14]
[INDEX_15]
[INDEX_16]
[INDEX_17]
[INDEX_18]
[INDEX_19]
Local_Time= 09/05/2005 13:37:14.109
[INDEX_20]
[INDEX_21]
[INDEX_22]
[INDEX_23]
[INDEX_24]
[INDEX_25]
Local_Time= 09/05/2005 13:37:14.125
[INDEX_26]
[INDEX_27]
[INDEX_28]
Local_Time= 09/05/2005 13:37:14.140
[INDEX_29]
[INDEX_30]
[INDEX_31]
[INDEX_32]
Local_Time= 09/05/2005 13:37:24.234
Err_Status= Status:0xb1040002-Location:0x30000000-Internal:0x01040000
Function= ncReadMult-CAN1::STD0X4B9
 biker2000
			biker2000
		09-06-2005
		10:10 AM
 - last edited on
		05-16-2025
		09:05 AM
 by
		 Content Cleaner
			Content Cleaner
I noticed that you're using NI-CAN 2.2. Could you install NI-CAN 2.3 and see if that resolves the problem?
-B2k
09-06-2005 10:21 AM
09-14-2005 06:45 PM
the problem persist. Perhaps, it's the same problem as the other forum: "network or object configuration is missing" because analizing logs from NICAN spy and from my application, this errors always occurs when the two applications are working simultaniusly. I have 2 programs, one use first port and the other the second port.
Thank's, Alex
 biker2000
			biker2000
			09-19-2005 06:17 PM
09-20-2005 04:30 AM - edited 09-20-2005 04:30 AM
Hi !
1. I'm using: CCA,PCI CAN, Series 2, DUAL PORT 9 PIN DSUB, REV C
2. I eliminate all call to the ncReset() call, buf the problem persist.
3. I send to you more and interesant logs. This examples are maked without card, only with the driver 2.3 installed into my notebook and without any call to ncReset.
a) Capture0.spy:
- The applications works blocking the calls to the driver, the calls to the dll does in sequence, not simultaniusly.
- The two calls to ncConfig() return the same error.
- The errors are correct errors because i don't have any card installed.
- The duration is above 1 second.
b) Capture1.spy (Is NOK)
- The applications works without blocking the calls to the driver, the calls to the dll does simultaniusly.
- The two calls to ncConfig() don't return the same error.
- The first error is correct error because i don't have any card installed, the second error is an internal error.
- The duration is too longer, there are time to take a coffy.
My question now (to my seft) is... which any precaution i will to take programing multithread applications that uses a 2 port cards? It's necessary to block all call to the driver? why the driver don't does this for him self?
I agree very much your interest.
Alexandre
Mensaje editado por 6pm
 biker2000
			biker2000
			09-25-2005 08:26 PM
09-26-2005 02:57 AM
Hi biker,
i have diferents internal errors when two applications are running without blocking calls to "nican.dll". With this action (to block calls) all the errors are fixed. I upload an example. Without call "ncReset()" the error of configuration is missing was fixed too.
Now i have all problems fixed and the application is running 24x7 since one week.
Salutacions, Alexandre
