ECU MC Toolkit problem with NI-9860 (problem a2l)
The ECU have two ports CAN. It works in the second port
Message 11 of 13
(1,149 Views)
Now I can read values of measurements ( using MC DAQ Initialise and MC DAQ Read), but some values are wrong ( value does not match the expected value). So I use specified address of measurement and Upload.vi to get value, always the some problem (I have the same result as method 1)
Is there any explications ?
Message 12 of 13
(1,142 Views)
Accepted by RchB
Do you have your vi setup with two separate threads for talking to the two ports?
> Open Port 1 > Send Msg to port 1 > Read Response from Port 1 > Close Port 1
> Open Port 2 > Send Msg to Port 2 > Read Response from Port 2 > Close Port 2
The port you open must be the port you Command/Read.  The hardware & software do allow for both ports to be active simultaneously.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 13 of 13
(1,125 Views)
