Automotive and Embedded Networks
Difference between Service data objects and process data object
Hi
Can anybody tell me what is the difference between SDO (Service Data Objects) & PDO (Process Data Objects).I am using 2 port PCI-CAN series 2 card.
If anybody knows the answer then please reply.
Thanking You
(7,421 Views)
SDOs are master/slave communications mainly used for drive configuration, whereas PDOs are used for real-time control and data transfer. You can send a PDO peer-to-peer or broadcast to all the devices.
I hope this clears some things up!  Please post any other questions you may have.
Chris R.
(7,412 Views)
Hello Chris
Thanks for the reply.
Can you explain more or suggest some link or documents on the SDO & PDO.
Raman
(7,408 Views)
See the online help file from our NI CANopen Library for LabVIEW for some basic informations about SDOs and PDOs.
More information should be available from the web.
DirkW
(7,399 Views)
