12-01-2015 07:55 AM
Hi all,
I am using 'ECU M&C" to get measurement data from an ECU using XCP DAQ list. The data is read at the sample rate I set in 'MC DAQ initialize.vi". This works OK.
I want to combine this data with measurements from my DAQmx device. Is there a possibility to synchronize the sample clocks (through RTSI?) in the same way you would synchronize CAN data with DAQmx data?
Hardware: NI PCI-CAN/2 & NI PCI-6229.
Thank you for any input.
PJ
12-02-2015 09:09 AM
Hi Pianne,
Assuming you have NI-CAN installed on your PC, you should have some examples on how to do this. In my LabVIEW example finder I can see some synchronisation examples under Hardware Input and Output > CAN > Cannel API or Frame API > Synchronization > Basic > DAQmx. There are examples on synchronising inputs which you can have a look at. Could you see if these are what you're looking for? IF they aren't then I'd be happy to assist further but I suspect that this is exactly what you're looking for.
12-02-2015 09:15 AM - edited 12-02-2015 09:16 AM
Hi Jake,
Thanks for replying.
Yes, I have seen the examples you talk about. I use this method (RTSI) to synchronize CAN inputs with my DAQmx inputs.
I was wondering if the same can be done with inputs I get through an XCP DAQ list. I haven't found any synchronization examples using XCP and 'ECU M&C toolkit'.
PJ
12-03-2015 04:35 AM
Hi PJ,
If both of the cards you're using have RTSI lines, and I believe they do, then you should be able to synchronise them just as you did with your CAN inputs. What NI driver are you using to collect these inputs?
12-08-2015 02:25 AM
Jake,
I am using DAQmx v9.6.2 to acquire analog inputs and the XCP DAQlist functions from "ECU Measurement and Calibration toolkit v15.0" to acquire ECU measurements from the CAN card.
My LabVIEW version is 2012.
I can export the refClock and StartTrigger from DAQmx, but I can't seem to find any XCP functions to import them to the CAN card.
PJ
12-10-2015 07:32 AM
Hi PJ,
Okay, I think I understand now, I'm not sure why I ddin't see this before. It's not possbile to do this with the ECU Measurement and Calibration Toolkit, so for XCP DAQ it won't e something you're able to do.
12-11-2015 06:18 AM
Thanks for clearing that up, Jake.
Not the answer I was hoping for, but still...
PJ
