9860 with cDAQ
Can a NI-9860, the dual port multi-network card, be used with a cDAQ chassis (PC controlled, not a RT chassis)? The readme for XNET does not specify a recommended hardware configuration for running the 9860 and the product page lists both cDAQ and cRIO...
Emach
(4,503 Views)
I don't have a Windows (ie non-RT) chassis to test with at the moment.  I do have a cDAQ chassis with RT and that card and it works great.  I would be extremely surprised if that didn't work in Windows, but does in Linux RT.  I have used other XNet c-series modules on USB, and Ethernet based chassis which required Windows, and it worked fine.  cDAQ until recently (like 2 years) typically meant non RT.  Only somewhat recently has the cDAQ chassis got embedded RT controllers.  So if it says cDAQ, I'd assume that means even the non-embedded cDAQ.
(4,493 Views)
Hooovahh,
Thanks for the reply. I've got the 9860 still in box with the "void" sticker intact. I'll keep the box sealed until someone happens by with a tested Windows non-RT setup as proof of concept.
Emach
(4,490 Views)
Accepted by Emach
The XNET readme explicitly calls out supported hardware. For the C-Series modules, the following chassis are supported:
  • CompactDAQ—NI-DAQmx 9.6 (or newer) is required for:
    • USB Chassis: NI cDAQ-9171, NI cDAQ-9174, and NI cDAQ-9178
    • Ethernet Chassis: NI cDAQ-9181, NI cDAQ-9184, and NI cDAQ-9188
    • Wireless Chassis: NI cDAQ-9191
    • cDAQ Controller: NI cDAQ-9138 (Windows and RT) and NI cDAQ-9139 (Windows and RT)
You don't mention a specific chassis but I can say that the 9860 does work in both USB and Ethernet compact DAQ chassis with a Windows host PC.
Jeff L
(4,486 Views)
I also wanted to mention that within the NI-XNET 17.5 readme, you will find additional cDAQ chassis/controllers that are supported.
The cDAQ chassis that are supported are:
cDAQ-9171/4/8/9 (USB)
cDAQ-9181/4/5/8/9 (Ethernet)
cDAQ-9191 (Wireless)
The cDAQ controllers that are supported are:
cDAQ-9132/4/5/6/7/8/9 (RT/Windows)
The version of NI-DAQmx driver needed will depend on which chassis/controller is selected and that can be seen within the readme.
Tommy
Tommy G.
Product Manager - Search, My Account, and Chat
(4,482 Views)
