Actor Framework Discussions
beginner in AF _ help me understand
Hi lab funs,
i am beginner with Actor framework (AF). Could you help me understand how to work with AF?
My app has 5 cylinders ( Gate, Lift, Shift, Grab, Clamp ), 3 Lamps ( Pass, Error, Servis), 2 Locks, Air distributed ( Vent, Sensor ) and HW Start button.
I made class of cylinder with methods ( Init, Move, Check Position ) and i made driver used QMH for this class.
Q1: if i want control 5 cylinders, i must make actor for each cylinder or only one ?
Q2: How i make comunication between actors cylinder and air distributed ( is free-running, every 1s check pressure then go to turn ON or turn OFF and send message to control actor if pressure = false )
THX
(6,931 Views)
I quickly looked at your example.  I think you would get benefit out of jon_mcbee's example.  It is an excellent at demonstrating QMH, QMH LVOOP and AF.  The link to the message is here: https://decibel.ni.com/content/message/61337#61337.  That has a 2013 link and a subsequent one has a 2012 link.
I also note that you are running 2010 and also recall you just joined the Actor Framework (2010) group.
If it is OK with jon, I will post a 2010 version of his example on the AF 2010 group as well as put a 2010 version of the AF 2013 - at least as best as it can be downgraded.  I cannot do that from work, so expect it to get there sometime tonight.
Anyway, after you review that, let's start this conversation again.  I think you will gain some ideas from simply reviewing his example.
-Kurt
(4,302 Views)
OK, check https://decibel.ni.com/content/groups/actor-framework?view=documents
There is the QMH example from jon_mcbee and a new ActorFramework release for LV2010 with no guarantees that it will fully work, but it does seem to work with the QMH example.  I do not see any reason that it wont work thougfh.
(4,302 Views)
Awesome, thank you for rolling this back to 2010.  I hope it proves useful!
(4,302 Views)
Thank you for your answer.
But i have lab 2012, i save this exam in 2010 because not many people has 2012 😉
(4,302 Views)
Hello everybody,
What do you think about this construction:
i have manipulator composite of 4 pneumatic cylinders. I create objects cylinder and manipulator each object has sequence. Cylinder has sequence: check position->desired position->stop & manipul has release->grip->upward->move->level->clamp. Manipul has also 4 parametre for sequnce ( Zon, Lev, Job, Clamp ).
Check my program.
Is it possible this program change to AF ?? Could you tell me how please ??
THX
(4,302 Views)
