Actor Framework Discussions
Is anyone using RT Execution Trace with AF?
I am working on analyzing the CPU utilization on a cRIO with a large AF application.  If anyone has experience that they would share I would appreciate it.  No sense recreating the wheel.  I will post follow ups as I gain experience if there is interest.
Casey
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
(3,974 Views)
Casey - any results on this?  I'm curious to know if you found anything interesting.
Cheers,
Matt Pollock
(3,467 Views)
Matt,
The biggest update I can report is that my CPU utilization was varying on different systems I had due to executing the Handle Error.vi method which contained a message with the error to an error logger. I suspect that the increased utilization was disk access.
A second "bad actor" was repeated calls to Handle Error.vi were a time delayed message was being sent. The time delay was blocking and upon release of the resource the CPU utilization would spike. I am imagining everything that was blocked playing catch up.
Note: deterministic code is in the FPGA and I am not in trouble if things are blocked for "some" time. I have revised my code in the sections that were of the highest problem.
Casey
Casey Lamers
Phoenix, LLC
(3,467 Views)
