Actor Framework Discussions
Launch nested actor.vi missing
I'm trying to install the LabVIEW CI Server. And it tells me I'm missing a vi called Launch Nested Actor.vi and gives C:\Program Files (x86)\National Instruments\LabVIEW 2014\vi.lib\ActorFramework\Actor as a path.
Is this supposed to be in the actor framework package?
Any ideas?
I'm using LV2014
(2,922 Views)
Launch Nested Actor.vi should be there... to probe if your AF lib is broken, create a new AF project using the assistant and check if the VI is in the library.
Different consideration: are you aware that the LabVIEW CI Server is not developed any further?
(2,904 Views)
