Actor Framework Discussions
Is Time Delayed Message Blocking in RT?
I have been observing a spike in CPU when there is a case of sending a time delayed message on a cRIO.  Is this a blocking function?
Thanks,.
Casey
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
Message 1 of 8
(6,321 Views)
Does "Time Delayed Send Message" still open a reference to a clone pool on each call?  Because that might cause a spike.
Message 2 of 8
(5,107 Views)
Accepted by CaseyLamers1
Aristos Queue informed me that the Time Delayed Message is blocking in RT as currently coded.
Casey Lamers
Phoenix, LLC
Message 3 of 8
(5,107 Views)
How does something "blocking" cause a CPU spike?
Message 4 of 8
(5,107 Views)
Maybe the time delay code is a fast loop? By the way that would be strange ...
I am also interested in how can it be..
Message 5 of 8
(5,107 Views)
It is my understanding that a blocking method pauses all other methods.  Upon release all methods that have been waiting will try to catch up.
I can say that if I increase the delay for sending the time delayed message that the corresponding peak gets higher until it reaches 100% and then it gets longer.
Casey
Casey Lamers
Phoenix, LLC
Message 6 of 8
(5,107 Views)
Worth noting here too that I recently removed some Time Delayed Message sending from my app, and saw pretty large performance benefits.  I noticed during a profiling run that the function takes quite a huge amount of crunching to do, _if_ you repeatedly send one-off messages to be sent in the future(very different from sending a recurring message).  It makes sense in hindsight since it creates a clone each time, but didn't notice for a long time.
But I saw times where it would take 100 ms on some cycles to actually perform the entire function.
So, were you using a recurring delayed message, or repeatedly using the send delayed message, one per call?
Message 7 of 8
(5,107 Views)
I was using it in "Handle Error.vi" of a Linked Network Actor when a connection error would occur.  I would wait 1000 ms and then try to reconnect.  It works, but with a big spike in CPU which prompted the initial question.
Casey Lamers
Phoenix, LLC
Message 8 of 8
(5,107 Views)
