‎01-22-2024 08:54 AM
Hallo,
I was trying to convert the labview example 'CAN signal input XY' and 'CAN signal output XY' to actor framework. I did some tutorials of AF but still couldn't succeed in converting to AF framework for the labview example. Could someome can help me in how to do this and learn AF?
Thank you in advance.
‎01-22-2024 01:21 PM
Sorry, it's not very clear to me what it is you're trying to do that's specific to Actor Framework. Are you trying to figure out how to replace the While Loop contents with repeated AF Msgs? Communicate the read data between two asynchronous processes?
Some higher-level information about what you're trying to ultimately accomplish might be helpful.
‎01-23-2024 01:46 AM
CaseyM
I was trying to learn AF. May be I will use a 'User Interface'(actor 1) to input data and an actor 2 to write CAN data and actor 3 to read data.
