07-14-2014 06:41 AM
Hi all
I had initially followed this link to create remote front panel so that I could remotely control the VI. This had worked fine then and when I try the same thing now on the development PC, it gives 'Access Error - 404' and displays that the document is not found. I tried even reinstalling all the softwares in the target, but of no use. I have turned off my firewall too. Any idea as to why this is happening?
Thank you
Arya
解決済! 解決策の投稿を見る。
07-15-2014 09:46 AM
Hi all
I finally was able to get the front panel running. I formatted the target, changed the firmware and kept on repeating the same steps as mentioned in the link above. At one point, it started running. I am unable to figure out how it stopped working and how it started again.
Arya
12-05-2014 11:41 AM
Hi Arya, could you please give me more details how you did it?, I have the same problem
12-05-2014 10:46 PM
Hi
Have you ever got it running on myRIO? What is the error you are getting? As I mentioned, in my case, it was working fine, all I did was to format, reinstall the softwares and update the firmware on myRIO and then follow the usual steps in creating a remote front panel.
Arya
12-11-2014 04:20 AM
Hello Arya1, thanks for your response, sorry for the delay.
Finally I did what you said, format and install software again. it works¡¡
Thanks¡¡
Icaro600
