how to install NI-DAQmx on windows 10 32bit
I've tried to install NI-DAQmx on Windows 10 32 bit, but it doesn't work, is it possible to install NI-DAQmx on Windows 10 32 bit?, how do I do that?
(4,808 Views)
you can use offline installer if you're having issues with the online one.
https://www.ni.com/en-us/support/downloads/drivers/download.ni-daqmx.html#
(4,740 Views)
Have you installed LabVIEW or Visual Studio before installing DAQmx driver?
It will work if you have already installed either one of the software because DAQmx is a driver and it is using in these softwares.
Also, if the installation doesnt work, you might want to remove the driver using NIPM and try to reinstalling using online or offline installer. Usually it will work.
DAQmx driver is compatible with Windows 10.
NI-DAQmx and Microsoft Windows Compatibility - NI
(4,461 Views)
Version
Full
32-bit and 64-bit
Cannot install using Offline version om 32 bit Windows 10. Insists only will run on 64 bit OS.
How to install on 32 bit OS?
(3,627 Views)
