external Source
i`m looking for some help. I use the myRio to read some Data from some Sensors. Because they need to much power, i have to use an external source. When i use this external source (socket), i think that i have to connect the ground Pin with the ground of the source. But i'm not shore.  Maybe i have to do nothing because the myRio use also the same source (socket), but when the Pins aren't coneccted with the ground of the socket, i have to pay attention. So can somebody help me?
thx
(5,894 Views)
Hello mtr86084,
generally you have to connect the power supply the same way as described in the manual:
NI myRIO-1900 User Guide and Specifications
https://www.ni.com/docs/en-US/bundle/myrio-1900-getting-started/resource/376047d.pdf
NI myRIO-1950 User Guide and Specifications
https://www.ni.com/docs/en-US/bundle/myrio-1950-getting-started/resource/376099b.pdf
Best regards
Veronika Kurz
Applications Engineering
www.ni.com/support
(5,857 Views)
