error code 363011 ADXL345 accelerometer with Labview and myRIO
I am using ADXL345 accelerometer and trying to interface it with Labview and myRIO. i downloaded the accelerometer demo from NI website. when i try to run the demo.vi, the error 363011 appeared. can i know what is the problem and how to fix the error?
gy291 adxl345 accelerometer is used.
(5,323 Views)
What is the error description that goes with the error code? The code on it's own isn't that useful - there's usually some useful information in the message that comes with it. Create an error indicator and select 'explain error', or use a simple error handler to get the error message.
(blog)
(5,297 Views)
I too am getting the same error which the error descriptor says "Undefined". I guess it's due to the register values that are being set to the write.vi. I tried running the same code using the Digilent ADXL 345 accelerometer supplied in the mechatronics kit and it was giving me proper results but once I connect another ADXL345 it throws me this error -363011. Can anyone help us out on the registry values to be set in the Accelerometer demo Main.vi..??
(4,062 Views)
I got the issue resolved. By changing the device address to 0x53, I was able to get the accelerometer data.
(914 Views)
