UART can't read data when set to startup
I use default UART to read data from XBEE , when attached VI executes , it response in 1 second .
But when I build , employ and set the RT-Application as startup , it doesn't work , I use LED to check and found that NO data read from UART .
(2,772 Views)
You may need to be replace the indicator(Characters Read 2) with a shared variable.
After that, you can also use this method to check whether the host read data successfully or not.
(2,735 Views)
