myrio stop rt
hey pro guys , I need someone help me now ~
I made a mistake on MyRIO . burned a while loop program without break button and break condition..
I can't stop it , even reset button or build something new to cover it ....
but all is not working
MyRIO is running a program all the time...
need some helps 😞
ps :  it was burned to detect acceleration all the time...
press "OK" is nothing work
(6,571 Views)
Accepted by topic author z7172930
Hello
Are you able to get to the browser based system configuration system
On the home page near the bottom of the system settings there is a checkbox labeled "Disable RT Startup App"
What happens if you check this and then power cycle the unit
Dan
(6,567 Views)
I followed your hint and finally , I got it
Thanks you very much:)
(6,551 Views)
I have tried unchecking it. it is still not working in my case. I ama using LabVIEW 2016
Senior Test Engineer
nkamal@hotmail.com
(2,946 Views)
I believe that the option in question should be checked
In your communication you state that you unchecked the option
Can you confirm what happens when you check the option and restart the CRIO
(2,943 Views)
