Python Example code for NI 9229
I am trying to use python so I can automate NI 9229 using NI cDAQ-9174. However, I am not able to find example codes that can walk me through it. I tried downloading pyDAQmx and used the following example from https://pythonhosted.org/PyDAQmx/examples/multi_channel_analog_input.html and replaced "cDAQ1Mod1_ai0" with
"Dev1/ai2","Dev1/ai1"]
It gives me the following error:
Traceback (most recent call last):
File "C:\Projects\Programming\NI\test1.py", line 57, in <module>
multipleAI.configure()
File "C:\Projects\Programming\NI\test1.py", line 38, in configure
DAQmx_Val_Volts,None)
File "<string>", line 2, in function
File "C:\Python27\lib\site-packages\PyDAQmx\DAQmxFunctions.py", line 29, in mafunction
raise DAQError(error,errBuff.value.decode("utf-8"), f.__name__)
PyDAQmx.DAQmxFunctions.DAQError: Device identifier is invalid.
Device Specified: empty string
Suggested Device(s): cDAQ1, cDAQ1Mod1, cDAQ1Mod3
Task Name: _unnamedTask<0>
Status Code: -200220
in function DAQmxCreateAIVoltageChan
Can someone help me?
Message 1 of 12
(12,500 Views)
Try using NI's internally-created, open-source, hot-off-the-press, just-released Python API and let us know what you think!
https://pypi.python.org/pypi/nidaqmx
http://nidaqmx-python.readthedocs.io/en/latest/ (documentation/examples)
(for completeness here is our GitHub Page)
Message 2 of 12
(12,459 Views)
I am receiving an error -201087 stating that "Task contains physical channels on one or more devices that require you to specify the Sample Clock rate. Use the Sample Clock Timing function/VI to specify a Sample Clock rate. You cannot specify a Sample Clock rate if Mode is set to On Demand."
I have NI 9229 and NI 9227 connected to NI cDAQ-9174 where NI 9229 is cDAQ1Mod1 in NI MAX. I have attached the code that I am trying to use.
Message 3 of 12
(12,449 Views)
Message 4 of 12
(12,441 Views)
I called the timing module and it worked. I have 2 DAQs (NI 9229) which I would like to use it at the same time. I am using NI cDAQ-9174 to put them together. Do I need to generate a clock using cDAQ1 i.e. cDAQ-9174? If so, how do I proceed forward?
Message 5 of 12
(12,424 Views)
Hi shpriyan,
Where you able to run the example?
Message 6 of 12
(12,406 Views)
Hi @Davidvilla87,
I am trying the example from https://github.com/ni/nidaqmx-python/blob/master/nidaqmx_examples/ai_multi_task_pxie_ref_clk.py and want to use cDAQ clock for 2 NI 9229 DAQs. However, I am unsure on how to use it.
Message 7 of 12
(12,399 Views)
Hi Priyank,
It is unclear how you would like the 9229 acquisitions timed. Would you like them to simply trigger off a timebase of the 9174, a counter of the 9174, or something else? If you would just like them to start acquiring at the same time, you can just select the same ref_clk_src for both channels. You could use a time base off the chassis, or you could use the AI sample clock of one of the 9219 channels. If you use that example, you would make one of the 9229's a master and the other one a slave. You would then select the same ref_clk_src for both the master and slave and they should be relatively synchronized, if that's what you are trying to achieve.
Message 8 of 12
(12,380 Views)
Hi all,
I am facing another issue. I installed nidaqmx in my another computer. I did pip install nidaqmx for python 2.7. I am unable to run the command nidaqmx.Task(). I see the following error.
TypeError: LoadLibrary() argument 1 must be string, not unicode
Exception AttributeError: "'Task' object has no attribute '_handle'" in <object
repr() failed> ignored
Detailed error:
  File "C:\NI_DAQ\NiDaqRun.py", line 50, in main
    with nidaqmx.Task() as task:
  File "C:\Python27\lib\site-packages\nidaqmx\task.py", line 84, in __init__
    self._handle = lib_importer.task_handle(0)
  File "C:\Python27\lib\site-packages\nidaqmx\_lib.py", line 173, in task_handle
    self._parse_typedefs()
  File "C:\Python27\lib\site-packages\nidaqmx\_lib.py", line 225, in _parse_type
defs
    version = system.driver_version
  File "C:\Python27\lib\site-packages\nidaqmx\system\system.py", line 73, in dri
ver_version
    return DriverVersion(self._major_version, self._minor_version,
  File "C:\Python27\lib\site-packages\nidaqmx\system\system.py", line 108, in _m
ajor_version
    cfunc = lib_importer.windll.DAQmxGetSysNIDAQMajorVersion
  File "C:\Python27\lib\site-packages\nidaqmx\_lib.py", line 161, in windll
    self._import_lib()
  File "C:\Python27\lib\site-packages\nidaqmx\_lib.py", line 198, in _import_lib
    windll = ctypes.windll.LoadLibrary(lib_name)
  File "C:\Python27\lib\ctypes\__init__.py", line 440, in LoadLibrary
    return self._dlltype(name)
  File "C:\Python27\lib\ctypes\__init__.py", line 362, in __init__
    self._handle = _dlopen(self._name, mode)
Message 9 of 12
(12,324 Views)
Message 10 of 12
(12,321 Views)
