07-14-2014 09:11 PM
Hey!
Currently I've got a system setup using NI cRio-9012, NI 9477, NI9263 and NI 9205.
This system has the following connect to the inputs/outputs:
1. Inputs: Receives 2 analog pressure sensor values
2. Outputs: 7 digital outputs connected to a driver circuit running hydraulic/pneumatic valves
3. Outputs: 2 analog signals to a driver circuit running variable hydraulic/pneumatic valves
The LabView program has 3 independent control loops that do the following:
Loop 1 and 2: receive input from the respective pressure sensor and control the variable valves (depending on input from user (front panel)).
Loop 3: Switch on and off the remaining 7 valves depending on input from user (front panel)
At the moment the cRIO system that I am using handles the whole system perfectly, but I am keen on a more portable system and intend to use the cRIO for a different application.
So my query is would myRIO be able to substitute the cRIO for my application? I do also intend to add additional sensors/outputs and communication too.
Thank you for going through my query!
Solved! Go to Solution.
07-15-2014 04:28 PM
The only potential issue I see with moving the project to the myRIO is the specs you might need on your I/O. For example, the 9477 is capable of 5 to 60V output where as the myRIO is only capably of 3.3V LVTTL output. Ultimately, it comes down to yours specific I/O needs - I've linked the manual and specifications for the myRIO-1900 below. I'd recommend looking it over to make sure that it will meet your application requirements.
NI myRIO-1900 User Guide and Specifications
On the software side, there shouldn't be too many adjustments that need to be made - the myRIO has the same processing architecture as the cRIO.
07-15-2014 06:48 PM
Thanks! Will check it out!
