How to set an application built using the C API 3.0 for myRIO to run at startup on a myRIO-1900
Is it even possible to set such an application to run on startup? If it is how would you go about doing it?
I compiled a program using the NI eclipse distribution and API and can run the program from Eclipse or by running it while SSH into the myRIO. The only documentation I could find relating to it is: http://digital.ni.com/public.nsf/websearch/B37FA04A1CB84B6C862571A30060EF03?opendocument&Submitted&&...
The link is a little outdated so I am not sure how relevant it is today. I changed the lines in lvrt.conf to:
RTTarget.ApplicationPath=/c/ni-rt/startup/startup.rtexe
RTTarget.LaunchAppAtBoot=True
None of the settings seem to do anything. I also tried launching the program like a script using rc.local which doesn't seem to be used the same way as it is in Ubuntu. My compiled pogram does not come with the extension .rtexe although I can add it later which might not be the same thing.
I made sure that the "disable startup programs" was unchecked on the myRIO webserver.
(4,483 Views)
Hi neap,
You might have more luck posting on the NI Linux RT forum, since that's where questions related to the NI Eclipse distribution and API are generally answered.
(4,449 Views)
Thanks. There are so many forums.
(4,446 Views)
Accepted by topic author neap
Just in case someone has a similiar question:
https://decibel.ni.com/content/message/144527#144527
(4,415 Views)
