06-04-2014 08:21 AM
Control is the FPGA control/indicator that you wish to write to (consider you have more than one 8 bit control, you need to tell it which one). The session is a way for the driver to know which FPGA bitfile you're talking about (and, in the case of systems that support more than one FPGA, which FPGA).
The NiMyRio19XX.h that matches your controller has the control constants in the header to control where the reads/writes go.
06-04-2014 08:24 AM
Sorry I did not make it clear,how can I use these 2 parameters?For example,have u seen my block daigram?I am still stucked in it:(
Thanks!
Sincerely,
John
06-04-2014 09:01 AM
Since this is a pretty clear "How do I use Eclipse on MyRIO" question, I'll leave it to the folks who deal with that more regularly.
