03-19-2018 07:10 AM
Where should I place SimulateSignal Express VI?
I am New to LabVIEW FPGA Plz Guide
03-20-2018 09:45 AM
Hi manya,
If you have LabVIEW 2017, use the NI Example Finder to load up the example Express VI - Amplitude and Level Measurements.vi. This demonstrates how to simply use the Simulate Signal Express VI inside a while loop. You can also read the Using the Simulate Signal Express VI to Generate Waveforms article and the Simulate Signal Express VI Help page.
If you're using the FPGA Module, use the NI Example Finder to load up the project Customized FPGA Signal Generator.lvproj. You can also read the Sine Wave Generator Express VI Help page to learn more.
03-21-2018 02:15 AM
As you suggested, I have used Customized FPGA Signal Generator.lvproj. to generate signal. Thanks
I have Attched code pic here, I want to generate sine waveform and diplay on the oscilloscope but I able to get DC levels on Oscilloscope Scope.
How to get Contineouse sine signal on Oscilloscope for given Code ?
03-21-2018 10:00 AM
I see from your screenshot that you're using a MathScript Node. What happens when you run a more simplistic example with, say, a sine wave? You can read the Analog Output Express VI Help page to better understand how the VI is used. Reviewing 1 Sample versus N Samples Modes (myRIO Toolkit) may also be helpful to make sure you're sampling the way you're expecting. Additionally, it may prove useful to review the code posted by users earlier in this thread.
03-22-2018 08:44 AM
Dear, I am new to LabVIEW FPGA. plz Send me relevant Video tutorials links for high throughput programming.
03-22-2018 09:44 AM
You can watch tutorial videos at Getting Started With LabVIEW FPGA. The Getting Started with the FPGA Module Help pages are also a good place to begin learning.
04-10-2018 08:13 AM
hello,
We have generated sine wave Successfully Thank You very much..
but We want to further modify our code so initially we want to add "for loop" in mathscript node,
when we have added for loop for further manipulations, the sine waveform is not coming properly .
04-11-2018 08:36 AM
hello,
04-11-2018 08:40 AM
I have downloaded a LabVIEW code to Ni MY RIO 1900
which has maths script node with for loop inside node but I could not get output waveform properly.
This is because of use of for loop inside maths script node. MY RIO BECOMES TOO SLOW.
Please guide
04-11-2018 11:01 AM
Hello manya,
I believe it is easier for the community to help out if you also provide the image of the changes you made to your code.
Additionally, what do you mean by the myRIO becoming too slow? Do you see a 100% CPU usage? Have you benchmarked the node/VI that is giving you problems? How fast do you need it to go vs. how fast it is actually running?
