ELVIS Scope problem
I am a new learner of Labview and have a problem using NI ELVIS.
I need to get an AI signal from BNC connectors( Scope connectors) on the control pannel of ELVIS, and write a labview program to analyze it.  But i find there is no such API for Scope function on the functional palatte.  So I guess I have to use DAQmx to write the program. If so, what is the device address of the BNC connector? Or there is other way using ELVIS API?
I know it might be a very basic question, but it really gives me a hard time to deal with it.
Thank you very much!
(8,400 Views)
Hi sinesquare,
NI-ELVIS have many Express VI you can use to acquire your data in LabVIEW. You should be able to find the Oscilloscope function in your functions palette as long as you have the appropriate drivers installed. This function should be under Measurement I/O » NI-ELVIS for NI-ELVIS I. However, if you have our new NI-ELVIS II board, than you have to install the NI ELVISmx drivers and the functions should show up under Measurement I/O » NI-ELVISmx
NI ELVIS Software 3.0.2 (for ELVIS I)
NI ELVISmx Software 4.0 (for ELVIS II)
I hope this helps,
S_Hong
(8,386 Views)
Thank you, H_Song.
 I installed the newest version for ELVIS, and it really works!
(8,383 Views)
hi, could you give me some examples using oscillscope express vi and function generator express vi?
Thank you!
(8,362 Views)
Hi sinesquare,
Unfortunately I could not find any examples using the oscilloscope and function generator express VIs for NI-ELVIS I as these VIs should be fairly easy to use. Is there anything in particular you are having difficulties with? Perhaps you could describe what you are trying to do and post your VI so we could have a look.
S_Hong
(8,343 Views)
