Can't program SBrio to move on a desired path
Hi there!
I am facing the following problems with my SBrio-9642-
1. I am unable to program it to move on a desired path. Do I need to modify the VI which is present in the rio memory? What changes do I need to make?
2. I have to interface a fire sensor with it. How can I do that?
(4,421 Views)
Shubh77,
1. What do you mean about programming to move on a desired path? Can you show us what you have done so far and what problems are running into?
2. Can you show us the specs of the particular sensor you have?
(4,390 Views)
