USRP Software Radio
gmsk
Hello
I am using NI-USRP 2900.
Does anyone have an experience with GMSK?
Regards
Eviatar
(3,687 Views)
Although I do not have personal experience progamming for GMSK, I believe I may be able to point you in the right direction.  The Modulation Toolkit should contain the functions that you need to perform GMSK using the USRP.  If you have the Modulation Toolkit, take a look at the MT MSK Mod-Demod.vi example in the Modulation Toolkit Examples.  I've attached this example as well.  You can do GMSK by choosing a Gaussian filter type in the MSK functions.
Jon F.
Jon F.
Technical Support Engineer
(3,675 Views)
how can we apply changing carrier frequency with every 1ms in the attached block of MSK.
(2,238 Views)
singh8865,
I noticed the original post is a few years old, so I would recommend you create a new thread to ask this question. This way, more forum members will see your post and you will have better chances of a quick response.
Patrick O.
Applications Engineering
(2,235 Views)
