12-02-2013 12:09 AM
Hi everyone,
I am using NI-WSN kIT comprises of gateway(9792) and NI-WSN NODES(3202,3212,3226 all programmable) and i am also trying experiments with NI-USRP 2921 so i thought to replace NI-9792 REAL TIME ETHERNET GATEWAY with NI-USRP 2921 as it is also operating on same 2.4GHz.
Can USRP 2921 act as a gateway or Not? is this is possible please suggest.
Warm Regards,
Abhinav Sharma
12-02-2013 12:14 AM - edited 12-02-2013 12:16 AM
The short answer is No.
The longer answer is that a WSN node uses a fixed function radio with a full protocal stack. The USRP is a general purpose radio covering a common set of frequencies however a fully functional turnkey stack does not exist. Could it be designed? Perhaps over the course of many focused man-years of development.
The USRP mostly used as a research device. Most research implements a small aspect of a protocol, ususally focused on the physical or MAC layer, and then customizes it and evaluates the results.
The right solution for WSN is a WSN gateway.
Erik
12-02-2013 01:00 AM
Thanks for replying soon......
