Switch Hardware and Software
Upgrade drivers when upgrading to LabView v.8?
After upgrading from LabVIEW version 7.1 to version 8.0 the Keithley 40-SR01 switch sytem (controlled by a 7002 main frame) does not function correctly.  So when upgrading from LabVIEW 7.1 to LabVIEW 8.0 do I need to upgrade the device driver also?
(6,479 Views)
Hi tcsieng,
You are correct. Just go to
http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E91CB659CE034080020E74861
and download the driver again. When you go to install the folder, just place it in the LabVIEW 8 directory instead of the LabVIEW 7 directory. You should then be able to access the functions to speak with the 7002 main frame with no problems.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(6,460 Views)
