08-31-2005 11:58 AM
08-31-2005 05:10 PM
First if you connect (4) 4x64 matrix tothe back plane you will make a 4x256 matrix.
Assuming that is want you want to do, you need to create a route from r0 to com0 and a route from com0 to ab0 to connect r0 to the analog bus. Create the same two routes for row 0, 1, 2 and 3 of all 4 modules. Place all the routes in the a route group and connect this route group at the beginning of your application.
Guy Ferraro
Switch Product Support Engineer
NI - USA
08-31-2005 05:31 PM
08-31-2005 09:40 PM - edited 08-31-2005 09:40 PM
I believe that you have to indicate that the analog buses are the same electrical connection, so that you can connect channels from one device to channels on another device. Therefore, you should create hardwires (or a bus) and put the ab0 through ab3 from every device on the bus.
I hope this helps.
Message Edited by SwitchGuy on 08-31-2005 09:40 PM
