NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member OD
Member
OD
Synchonous acquisition using NI 9426 and NI 9201 on a DAQ 9172
I'd like to synchronously acquire both digital and analog data using lower-level DAQmx VIs. For some reason, I cannot configure correctly my difital task.
 Here is the Vis for this project that is aimed to record voice and press-button board.
Thanks for helping
Trusted Enthusiast
DFGray
Re: Synchonous acquisition using NI 9426 and NI 9201 on a DAQ 9172
You accidentally posted this to the wrong forum.  Repost in the LabVIEW forum and you should get a swift reply.  Unfortunately, my DAQ skills are not good enough to give you much help.
Using LabVIEW 2009 - 2012 on Windows 7 64-bit
Active Participant
alcava.cr
Actually, it will be ideal to post this thread in the Multifunction DAQ board. Plus, there is an example called "Multi-Function-Synch AI-Read Dig Chan.vi" at the NI Example Finder under Hardware Input and Output»DAQmx»Synchronization»Multi Function that does exactly what you are looking for. A piece of advice, the shipping examples are built using DAQmx low level APIs so it would be a good Idea to check there first, plus. I would recommend not to use the timed loop unless you are running your application in a real time OS. Good luck! :smileywink:
Alejandro | Applications Engineer | National Instruments
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
