02-08-2009 11:26 AM
02-09-2009 08:00 AM
Could you post your project with log file so we can look at the problem? Thanks!
Note, if the log is too large, we can use the FTP site to transfer your data. Let us know if this is an issue.
02-09-2009 09:51 PM
Thanks for attention and help.
I am submiting simulated signal log (original was too big). I noticed that if you use "Detrend" data in some other analysis function in playback, it works fine. But if you just want to graph it's result without further processing, data stream apears empty. .
In submited meta VI everythink appears to work, but if you delete two postprocesing steps, save the project and check detrend data- nothink happens (except closing the detrend probe crashes Signalexpress).
Maybe this is intended limitation to restrict Detrend Data step to preprocessing.
Appreciate your support.
02-11-2009 12:22 PM
03-03-2009 09:30 AM
I reported this issue to R&D (CAR#146217) for further investigation. I apologize that you were experiencing this functionality. I would avoid trying to use the probe feature for these steps until we find what is causing this and how to avoid the undesired behavior. Thank you for the feedback!
