SignalExpress
How to run an acquisition on Signal Express with the windows cmd.
I try to make a consumption measurement on Signal Express. But I would like to to run this measurement with a command prompt. I don't find the solution in the user manual.
Do you know if it is possible ?
Thank you
(4,134 Views)
Good Morning,
Could you precise me the Signal Express used , the Light Edition or the Full version ?
Cordially
Arnaud
GENEBRIER
Ingénieur d'Application | (NI France)
(4,102 Views)
I use the full version.
(4,098 Views)
Unfortunately , there is no way to control Signal Express by the command prompt or by other way such as active X ( This feature doesn't exist in SE ).
The only solution will be to develop an executable under LabVIEW and parameter as following :
http://digital.ni.com/public.nsf/allkb/17C3AD70493CE0208625666A00763364
Cordially
Arnaud
GENEBRIER
(4,087 Views)
Accepted by topic author labppt
Thanks a lot. We are moving to Labview, this should solve the issue.
Francois
(4,016 Views)
