09-24-2014 05:22 AM
Here is a fig of how it looks when connected to port 1 and 2 respectively. I also see that the DNS name did not say .local in my first screenshot from last week.
10-01-2014 02:54 AM
Hi glorias,
if you reboot your cRIo-9068 to a safe mode, are you able to see something on the network tab. So check the Force Safe mode selection in the System Settings. And then reboot the 9068.
Br, Jorghos
10-13-2014 04:07 AM
Hi Jorghos!
Sorry for late response, but this actually worked, thank you very much! I also changed some things before that, allowing java scripts, active X etc. But this was the final thing that made it work and now I do not dare to change anything else back to start with.
Thank you for all the help from everyone!
10-14-2014 02:14 AM
Hi glorias,
great that it helped. I don't know what setting caused this but usually the safe mode can help on getting the system back to a normal state.
Br,
Jorghos
