Manually Deploy Web Service to cRIO Real-Time Controller
I have a web service running on a cRIO controller - it work as design. According to the following documentation What happens when I deploy my Web service? you can manually deploy a LabVIEW .lvws file if the service is self contatined. Has anyone been able to do this on a cRIO controller?
(4,267 Views)
I've never manually deployed a webservice, but I have manually deployed files to a cRIO using the FTP server. According to the documentation if the VIs, shared libraries, and data files contained in the .lvws file are complete and self-contained you should be able to push it over to the cRIO using the FTP server.
What steps have you tried so far? Where are you at?
Applications Engineer
CLD Certified
(4,246 Views)
