PXI
hardware setup using chassis PXIe-1065: Generate sine tone
We have an NI PXIe-1065 chassis with a
-PXI 5610 and PXI 5442-AWG together (VSG) and
-PXI 5600 and PXI 5142-Digitizer together (VSA).
We are following the manual RF application development course manual- Exercise 2.1
We have made the following external connection in our chassis as per the manual:
5442 Ch 0 to 5610 INPUT (15-35Mhz)
5442 Clk in to 5610 (10 Mhz OUT)
5412 Ch 0 to 5600 OUTPUT (50 ohms)
5412 Clk in to 5600 (10Mhx OUT)
Are we missing any other connections?
We want to generate a sine tone using VSG, Max test Panels and acquire a spectrum using VSA and Max test Panels. However after we  change the frequency and Power of NI567x tab in the NI 5610, we get the following error:
The AWG reported the following error:
"DAQmx Error -200245 occurred:
Measurements: PLL could not phase-lock to the external reference clock.
Make sure your reference clock is connected and that it is within the jitter and voltage specifications. Also, make sure the reference clock rate is correctly specified.
Device:  Dev1
Status Code: -200245
Please advice us what to do.
Prads
(3,501 Views)
Also i want to identify my PXI chassis.  Upon right clicking "PXI System(Unidentified)", which gives a list under "Identify As", what has to be selected?. Should I select the External PC because I connect the chassis to a PC. I have he NI PXIe 1065 chassis with a PXI 5661 and a PXI 567x, and a PXI 5690 Pre-amplifier. Kindly advice.
prads
(3,484 Views)
I debugged the error. The cables were bad.
Prads
(3,461 Views)
Hi Prads,
I’m glad that you solved the error. Regarding the second question in your post, yes you should select ‘External PC’ when identifying the chassis if you are connected to it through a PC using MXI. Regards,
Ana P
(3,458 Views)
This post has been answered here.
Ana P
(3,456 Views)
