03-15-2024 08:01 AM
Hi, we are using the following boards within our system :-
PXIe- 8301 (785679-01)
PXIe- 6592 (783639-01)
PXIe- 8238 (784976-01)
PXIe- 7962 (781206-01)
PXIe- 6672 (780063-01)
PXIe- 6547 (781011-03)
PXIe- 4463 (783086-01)
PXIe- 4492 (781490-01)
Does anybody have MTBF figures for these items ?
03-15-2024 10:10 AM
As per this article, you need to request it,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kKbdSAE&l=en-US
03-18-2024 03:41 AM
Thanks for pointing me in the right direction - I'm new to the forum!.
03-21-2024 06:20 AM
I am also interested in this process, and why do you needs the information. It will be very appreciated if you could share the experience requesting the information. 🙂
03-21-2024 06:29 AM
santo_13 sent me a link
I require MTBF data to enable a detailed RAM Analysis of a complex system where our customer has set RAM Targets to achieve.
Data provided by NI is good but could do with being a little more specific regarding environment and temperature assumptions for the calculated MTBFs.
Hope this helps
