11-03-2015 10:28 AM
Is it possible to use the vector transceiver Ni PXIe 5645R to capture 1msec burst generated from an outside FPGA board?
I just want to characterize the captured burst so I can export it after that for post processing.
If possible, what exactly I need for the hardware connection and Labview
modules?
11-04-2015 04:50 PM
Would you be able to go in more details regarding this 1 msec burst? Is this an analog or digital signal? If so, what is the frequency and power level of the signal within the 1 msec burst? The 5645R can capture signals within frequency ranges of 65 MHz to 6 GHz. Also, what I/O hardware connectivity is used with the FPGA board you have?
