PXI
Ni 6587 using FIFO Target scoped and FIFO Target to Host
Hi Everybody
I am using NI-PXI7952 + NI 6587 + NI SMA-2164 for acquisition of LVDS output data from Analog to Digital Converter (ADC) 8 Bits. Output Speed 250MHz. Output level : Vos=1200mV,  Vod=800mV.  with R=100Ohms.
First question: Is it possible to bypass the terminaison of 110 Ohms inside the NI6587?
Attached to this message: photo of the test bench, Diagram1 for the Host program, Diagram2 for the FPGA program.
We want to capture data from the ADC,
After the execution of the host program, LBV return the error -50400 which mean the FIFO was empty.
After the execution in mode debug of the FPGA program,  LBV return OK(60300) .
The FIFO are declared as follow:
FPGA
Clock Domain FIFO
Data Type: Cluster
Number of Elements 1023
HOST
FIFO_HIGH
Data Type: U32
Number of element: 4095
FIFO_LOW
Data Type: U64
Number of element: 1023
Could you please tell me what I need to do to fix the errors?
Thanks for your help.
Papacifacile
(4,378 Views)
Nope. Why would you want to remove the differential termination on the LVDS lines?
Are you trying to read from the FIFO on the host side before the FPGA has begun sending data to the host? Try running in simulation mode to see if you can identify whether you're failing to put data into the FIFO on the FPGA, or if you're reading on the host before the FPGA is ready to put data in.
(4,355 Views)
