01-16-2007 10:56 AM
I have four NI PXI-8184RT controllers (w/Real-Time Embedded SW). There is no Windows OS on these RT, they boot with LabVIEW RT 7.1 (Pharlap ETS). I wonder if these controllers can use the floppy disks created with MAX under RT Disk Utilities (PXI Format Hard Drive Disk, IP Reset Disk…). The thing is that PXI-8184 don’t have a floppy, we have to use USB floppy.
I changed the following BIOS settings on the 8184 to use a USB floppy:
AdvancedàIntegrated PeripheralsàLegacy USB Support [ENABLE]
BootàRemovable DevicesàLegacy USB Support [moved to 1st position]
I can see the LED going on the USB floppy, but that’s all… the controller then boots from the hard disk. The problem is that I’m almost sure that this OS doesn’t have any driver for USB mass storage or USB floppy.
So if it is the case, is MAX the only way to format the 8184? I know that we can force booting from safe mode from the BIOS, does that feature replaces what we would do with a PXI Safe Mode floppy disk?
Patrick.
01-17-2007 05:28 PM
01-18-2007 08:35 AM
Hi Steven,
if I can format the hard disk from the 8184's BIOS, I'd really like to know how... I couldn't find that option.
Thanks for you answer.
Patrick.
01-19-2007 10:27 AM
