NI TestStand
breakpoint bit
Is there in Teststand Context a bit that shows if the breaktpoint was set?
(4,268 Views)
I'm not sure I follow what you are asking.  Do you want to see if they breakpoint is enabled?  Or if the condition for it was met?  Or if it even exists?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,261 Views)
I want to see if it was enabled.
(4,247 Views)
Put this in a statement step :
Locals.bool=RunState.Engine.StationOptions.BreakpointsEnabled
This returns True for enabled.
Ravi
(4,233 Views)
Thanks SunRS, but that wasn't my purpose. I want to see if the breakpoint is set or was set in step(s) before.
(4,211 Views)
Accepted by topic author Rokot
See the API help for: Step.GetBreakSettings()
Hope this helps,
-Doug
(4,204 Views)
