04-13-2015 07:11 AM
Is there in Teststand Context a bit that shows if the breaktpoint was set?
Solved! Go to Solution.
04-13-2015 09:50 AM
I'm not sure I follow what you are asking. Do you want to see if they breakpoint is enabled? Or if the condition for it was met? Or if it even exists?
04-13-2015 11:19 PM
I want to see if it was enabled.
04-14-2015 05:41 AM
Put this in a statement step :
Locals.bool=RunState.Engine.StationOptions.BreakpointsEnabled
This returns True for enabled.
Ravi
04-16-2015 02:14 AM
Thanks SunRS, but that wasn't my purpose. I want to see if the breakpoint is set or was set in step(s) before.
04-16-2015 08:02 AM - edited 04-16-2015 08:02 AM
See the API help for: Step.GetBreakSettings()
Hope this helps,
-Doug
