Webservice using Testand.Engine
I would like to write a Webservice that monitors my Teststand on demand.
The service should be done in C#
Here is my Question:
Is it possible to access the running Engine ?
greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,199 Views)
As the TestStand Engine is always loaded only once, there is no expicit method in the API to attach to a running instance, but if you create a new instance of the Engine class, it should be connected to a already running instance of TestStand.
If you ar using TestStand 3.0 or later, you could use the "Application Manager" Object, and call the method "GetEngine" method. this will give you a Refereence to thr running TestStand Engine as well.
Hope this helps!
André
(4,186 Views)
Hello Andre
Thanks for your reply.
It sounds good. But just one Question.
What is Application Manager Object ? Maybe i am blind but I can not find it in the Teststand 3.5 API
or is it an additional NI-API
Greetings from the Lake of Constance
Juergen
--Signature--
(4,179 Views)
Sorry, I forgot to mention that the Application Manager Class is part of the "NI TestStand UI Controls 3.5 (ver 1.0)" Automation Server.
(4,173 Views)
To clarify, what Andre states applies to a single operating system process. There is only one engine per process. If you must access an engine in another process, you must somehow arrange to have a reference to it marshalled to your process. This is the same for the engine as it is for any other activeX object that resides in an external process.
(4,168 Views)
