07-21-2011 07:14 AM
I am trying to build a deployment system with TestStand 2010. I want to install everything associated with the package to, say
C:\ProductionTest
So, I chose Default Installation Base Directory set to "Windows Volume (e.g. C:\)" and the Default Installation Subdirectory field set to
1. \ProductionTest
2. C:\ProductionTest
None worked. Whatever other attempts I made resulted in the installer trying to install under
C:\Program Files (x86)\National Instruments\
Also, I have checked the box with "Do not ask user for install directory", but the installer asks for the install directory?
Whatever I do it looks as if the installer always comes with the defaults. Anyone has a suggestion?
Marco
11-23-2016 11:43 AM
Your Default Installation Subdirectory should be:
Production Test
Dont used the back slash at the beginning
regards
Ray
