NI TestStand
NI Teststand deployment utility
I have created ni teststand installer and trying deploy on target machine. After successful installtion it shows .seq file in "program files" folder of my windows directory. Even if the NI Teststand engine is installed, i am not able to run .seq file.
System details:
LabVIEW 2015 (32 bit)
Teststand 2014 (64 bit)
Windows 10 64 bit OS
Thanks in advance.
(2,759 Views)
Do you have  TestStand User Interface deployed as well as the TestStand Engine?
regards
Ray
(2,688 Views)
(This seems like a revived thread)
You need a deployment or a TestStand license to use/run sequence files.
To run without TestStand, go in Start Menu under TestStand and select UserInterfaces. You can run TestStand without a full Developers license. As long as you have a deployment license.
(2,683 Views)
