This mean in the Specify Sequence Call Dialog, you have set the control for New Execution?
If this is the case you just specify you parameter values in the Parameters control on that Dialog. So you should see your three parameters listed in the Parameters control. select each parameter an enter the expression that matches your values you wish to pass the the sequence.
I hope I have understand you correctly.
Ray Farmer
Ray Farmer
