How to transfer Station Globals from 2.0 to 3.1
I have a Teststand 2.0 sequence.  I notice that after I install 3.1 it can not access the previously existing station globals.  I can enter them by hand but I need to deploy to other machines.  Is there a way to import station globals from 2.0 to 3.1. A collegue suggested copying the .ini file but I notice those files have teststand versioning entries.
(3,499 Views)
You should be able to copy this file to 3.1.  The versions will change once you save the file in 3.1.
Allen P.
NI
(3,495 Views)
And How to import station globals from TS3.1 to TS4.2?
(3,171 Views)
You should be able to do the same as Allen P had responded to the previous query. So did you try that.
Also what's the point in posting your query here and in it's own post (here), it doesn't get your query answered any quicker.
Regards
Ray Farmer
(3,164 Views)
