NI TestStand
How to add a custom table in Teststand Report?
I want to add one user defined table with some filled data and other datas should be filled from data coming from Labview scripts. How to do this?
(3,215 Views)
Hi Bose,
You can actually select to include tables in your report within the Report Options. You will have to have stored this data into a TestStand variable such as step.results.resultsarray. You can then open Configure -> Report Options and in the dialog select "Include Measurement" and under the Include Arrays select Insert Table. There is a great example of including arrays in the report as a graph at \Examples\DisplayArrayInReport. You can change the options to display the results as a table instead of a graph using the above steps.
Caroline
Caroline Tipton
Data Management Product Manager
(3,199 Views)
