Hi Bose,
You can actually select to include tables in your report within the Report Options. You will have to have stored this data into a TestStand variable such as step.results.resultsarray. You can then open Configure -> Report Options and in the dialog select "Include Measurement" and under the Include Arrays select Insert Table. There is a great example of including arrays in the report as a graph at
\Examples\DisplayArrayInReport. You can change the options to display the results as a table instead of a graph using the above steps.
Caroline
Caroline Tipton
Data Management Product Manager
