NI TestStand
How to act on bitwise data
So, I have a number saved in Locals...
Call it Locals.BurnerState  of type (number)
I want to do something if the umm... 4th(?) bit is set (16)
So, I Tried
If 16 AND Locals.BurnerState =1 then.... nope
If 16 AND Locals.BurnerState ==1 then.... nope
If 16 XOR  Locals.BurnerState== Locals.BurnerState then.... nope
If 16^Locals.BurnerState== Locals.BurnerState then... nope
tried moving the 16 to the other side... still nope
The Expression Builder keeps telling me that the expression is not evaluating to a boolean
(Heck, It does not even like if Locals.BurnerState== Locals.BurnerState then)
1. what am I missing with respect to building the If/Then construct
2. Is there a better way to act on specific bits (Flags actually...)
(4,947 Views)
So bitwise arithmetic takes the bits from one number and performs them agains the bits of another number.
For instance if I have 2 and 3 the bits look like 10 and 11 respectively.
So 2 AND 3 translates to 10 AND 11 = 10.  1 AND 1 = 1, 0 AND 1 = 0
So 2 AND 3 = 10 = 2  Your end value is a numeric.
Using my example if I want to check bit 2 (N) then I would do something like this:
2 >> (N-1) AND 1
2 >> (2-1) = 01
01 AND 1 = 1
1 = True
So your example should look like this:
((Locals.BurnerState >> (4 - 1)) AND 1) == 1
BTW ">>" is a shift operator which shifts the number by N bits.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,934 Views)
Accepted by Everseeker
Other option:
(Locals.BurnerState AND 16) > 0
jigg
CTA, CLA
testeract.com
(4,931 Views)
Thanks.
Combining the info you provided, plus a little more from reading, I came up with
If ((Locals.BurnerState & 0x10) >> 4) == True
If ((Locals.BurnerState & 0x08) >> 3) == True
If ((Locals.BurnerState & 0x04) >> 2) == True
If ((Locals.BurnerState & 0x02) >> 1) == True
If (Locals.BurnerState & 0x01) == True
to test all 5 bits & act accordingly.
(4,900 Views)
Why wouldn't you just do:
(Locals.BurnerState & 0b11111) == 0b11111
That will test them all at once and is a single line.  Or are you just showing how you test them individually?
jigg
CTA, CLA
testeract.com
(4,893 Views)
I am using them as individual flags, So I needed a way to detect any one of them in an IF statement
(4,887 Views)
