NI TestStand
Display a default subsequence when openning a sequence file in the TestStand editor
Is there a way to set the default sequence displayed when openning up a sequence file?
Seems that the steps for MainSequence are typically displayed first when openning an existing sequence.
How do I set it to display another subsequence I created when I open the sequence file.
Or if it is displaying a subsequence other than MainSequence, how do I set it back to display MainSequence by default when reopenning the file in TestStand.
(4,138 Views)
Accepted by JeffC
Jeff,
Sequences are stored in sequence files in 0-N order.  The default sequence will be the 0th one.  To change the order in the sequence editor you can click on the Sequence bar above the sequences.  Keep clicking until there are no arrows on it.  This is the true order of sequences in the sequence file.  Drag the one you want visible to the top.
See the image so you know what I'm talking about.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,130 Views)
