You could add a SequenceFileLoad callback so that the cal step is only run when the sequence file is loaded. Save the result to a station global. Whenever you do a test, make the step result equal to the measurement minus the variable. There are other ways to do a test only once such as a precondition where it depends on a variable that you would update after running the test.
