See discussion here: http://forums.ni.com/t5/NI-TestStand/TestStand-and-LabVIEW-treat-polymorphics-with-instances-with/m-...
Say I have a LabVIEW Class, and that class contains a method that's a polymorphic VI, and that polymorphic has instances. If I set the instances' access scope to private, and the polymorphic to public, then I can force developers that use the class to use the polymorphic VI (and not call the instances directly). That's awesome. I like that.
but...
Say I'm building a TestStand API that uses a polymorphic and its instances as described above. I create a LabVIEW action step, with a Class Member Call call type, and I target my class. TestStand doesn't support polymorphic VIs, which means neither the polymorphic nor its instances show up in the Member Name list.
This means that, to support my LabVIEW users and my TestStand users, I need to create two separate APIs. The idea is to modify TestStand to allow for Polymorphic VI spacing between the LabVIEW action step type and the polymorphic member VIs.
